Arlo Secure geofencing not working
Arlo Secure geofencing not working. Have samsung s22+ and iPhone 13 mini (latest OS on both). Invite the iPhone as shared, set up just fine, see it as a shared member on the s22. Set up geofencing routine leave home and home mode correctly. Location service on for s22 and iPhone enabled correctly. Go out of the geo fence and no notification that leave home is enabled. Open App, App switches from home to leave. All cameras work fine and report detection. When moving back inside the fence, arlo does not switch. Open App, App switches back to home mode. This issue has happened when replacing a pro 2 camera with a pro 5 camera. I was forced to update Android App to Arlo Secure. Prior to the upgrade, geofencing worked fine on the old App. Using a base station, not wifi. In the iPhone arlo App, cannot set up location, home or leave modes. As it's shared I guess it gets its location and set up info from the s22. The whole arlo system is useless without geofencing working properly from both devices, please help
Same issue. I can not even find an option to add geofencing or individually arm / disarm the cameras. I was also forced to update when adding the new doorbell and have been fighting for the past few days to resolve by working with support but have had no luck at all.
Geofencing is enabled in routines then automation. I have set this up but geofencing not working and when I force the leave mode no notification. The old App worked fine. No feedback from Arlo yet
Post screenshots of your GF automations. We may be able to get you going quickly when we see them.
I think I have found the issue with geofencing. In routines/automation and leave I had notifications set to email. I had both the android and iPhone email addresses listed. Today I removed the email addresses and selected notify everyone. Took both phones out of the fence and arlo enabled all the cameras. Came back inside the fence and arlo disabled as it should have. Early days for this change, will report back later. Some pics of what I have done. Each phone got notificatios as each mode was enabled
Has this configuration continued to work for you? I have reported faulty geofencing performance multiple times. Now Arlo only appear to respond if you have a subscription plan, so it would look like geofencing is not included. No responses to my last case report. Very poor technical support and morals after an expensive buy 😡
Case numbers 569014 dated 17/10/23 and 540817 dated 6/8/23 ... no response to the latter case and geofencing location status for devices remains blank. No notifications on location changes so device reporting is completely failed.
Hi there. Yes arlo geofencing is working but no email notifications. Still have an issue if both phones are together ie both of us go out in the car together, there are no notifications at all when going outside of the fence. Arlo enables the away mode but no notifications. If the phones are apart then notifications are heard and away is enabled. Coming back inside the fence, no notifications are heard when both phones are together
My Geofencing is no longer working
It's been a headache since i got the cameras 5 years ago
sometimes it worked , and then after an app update, it no longer would
then after months, it started working again.. who know why and how
Right now, the app registers both users correctly when they are in/out of the zone,
But the system will not arm & disarm by itself.
i also switched on 'location in/out notifications", but do not get such notifications
We have
iphone 12 mini - latest ios
iphone 11 - latest ios
arlo pro 2 - base station: 1.21.1.0_4302_9611cf3 / hardware VMB4000r3
i have completely reinstalled app on both phones (several times)
restarted base station several times and even unplugged it for several hours
If anyone has an ideas....
follow up
thank to Jeffrey from Arlo, managed to get it to work again
- i deleted the base station from my app
- reset base station
- switched base station off for 30 seconds / then on again
- re-added base station to the app
cheers
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
