Arlo Pro 4 camera sensitivity settings
  • 2999 Views
Somervre
In the app, if I go into Mode, Armed, If motion on (camera name), Motion detected...there then is a slider called "Motion Sensitivity".  By default it seems to be set to 80.  I have always assumed that setting the number to higher (like 100) would mean it was more sensitive and would pick up motion quicker.  But there are icon of a man standing still at the low end of the slider, and an icon of a running man at the high end of the slider.  To me, I could interpret that to mean that there needs to be a lot of motion (like a man running) to trigger the motion detection at the higher levels.  That is opposite from what I assumed.  So which is it??  Higher settings = less sensitive or more sensitive?
100 is the most sensitive setting, 1 is the least sensitive.
Somervre
Are you sure?  Doesn't the icon indicate otherwise?
I am sure.
But I agree the icon is open to interpretation.
