  • 4 Replies
  • 1510 Views
FreeKenBass
Arlo H3 on Arlo Hub
Arlo Pro 4 on Wifi
I want to keep recording after motion is not detected.  When I choose device and Utilities, I don't see an option to adjust the recording length
@FreeKenBass wrote:
3. If I choose Mode, I get a page that allows me to Arm or Disarm my Hub and Cameras.
You can edit the rules in the Armed mode to control the recording length (and motion sensitivity).
Do you see Library or Feed to view recordings? The answer is different between the 2 interfaces.
For Library, you edit your modes and rules. The duration of recording is set there - choose the timed recording and set the length for up to 2 minutes.
For Feed, edit the camera settings and then Default Mode Settings. In there use the same strategy as above.
FreeKenBass
Thank you for your response.
I am using Arlo Secure
I do not know what you mean by "Do you see Library or Feed to view recordings?"
When I go to the online Arlo Web  Portal on my PC, I see Devices, Library, Mode, and Settings.
1. If I choose Devices, I can see my six cameras.  If I click on the gear icon on one of my cameras it gives me options to set up the camera, but no record length options.
2. If I choose Library, I see all of my recordings but no place for record length adjustment.
4. If I choose Settings, and drill down to the settings in each camera, there is no reference or option for recording length.
Am I looking in the wrong place for the record options?
FreeKenBass
Thank you for helping me.  It works just as you said.
