Suddenly our siren is going off at random, not related to any motion detection. Also, Arlo secure is showing a notification that I can't clear on my phone indicating "Activate Siren" and looks like it is trying to download something. Have restarted base station and phone. Is this a hardware or a software problem? How can I fix this? Thanks.
Thanks. After restarting base station over a few days and reinstalling the Arlo Secure app on my phone the problem seems to be corrected. I think uninstalling/reinstalling the phone app may have been the key. I appreciate your help on this.
I have not seen this issue reported for a long time, nor any explanation.
The usual workaround is to manually force activate the siren from the app then manually reset the siren from the app.
You have the option to acknowledge the siren by pressing the Base station top button.
I suspect that the random siren is firmware related so if you have subscription plan you can escalate it with arlo support via the app settings/ support path.
If you don’t have that option you could try power cycling the base station daily for a few weeks to clear out any corrupting data bits in the base station memory.
You’re welcome although my opinion is that a base station fault is more likely.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
