Arlo Application on iPhone not upgraded
Hello Friends
I have two Arlo Ultra 2 and two Arlo Pro 2 working on two different stations.
Talking with a friend of mine having his Arlo Ultra 2, I saw that his iPhone application was totally different from mine.
It seems than mine is not the latest one.
I cancelled it to reinstall it but I am still on the same app version.
Can you please help me ?
There are two different user interfaces supported in the app. The older UI shows "Library", the newer one shows "Feed" and "Dashboard".
You can migrate from "Library" to "Feed", but there is no way to migrate back. There are still some issues with "Feed" - and one major limitation is that "Feed" doesn't support custom modes.
Personally I think you should stick with "Library" until Arlo migrates everyone to "Feed". But if you want to migrate now, the way to do that is to go into "add device" and then start to add a Pro 5s camera. You can't complete that work flow (since you don't have the camera). But it will migrate you to "Feed".
Honestly I didn’t understand the interest to migrate.
and if this new UI is not operational and stable, I prefer to stay on the good old Arlo UI.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
