Hi,
I have an Arlo 2 Go which I rely on LTE connecrion. Over 3 weeks ago it stopped working on LTE after a firmware update. I have spent many hours with support on this and no resolution. This included being sent a replacement camera and it had the same issue. WIFI works, but I have no wifi where it is installed. I have been told its an "engineering issue" and its with the engineering team but I have no idea of resolution date, only its a priority. As far as I am concerned the camera dossnt work and the whole experience has been extremely frustrating. I have prepaid for 12 months subscription which is not being used as I have no working camera, plus my remote shed has no security. Can you please refund the balance of my subscription. I am going to take the camera back to place of purchase as it doenst work and I need to purchase a different one. Chris
Does the camera work in a different location (either near where you want it mounted or elsewhere)? How is the signal strength from the nearest cell tower? Which provider are you using?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
