App glitches on devices tab. Cameras show up as normal then one by one go to “appears offline” screen. I know they’re working properly and if I catch it before it turns, I can live stream.
What camera models?
Are they connected via a hub? Or are they connected to your home wifi?
Is this also happening on a PC (my.arlo.com)?
I have a few different camera models. Newer ones are essential floodlights. Older ones as well They’re connected to a home base station via Wi-Fi. This is happening on my iPhone app as well as ipad app. Do not have a pc or laptop
The only floodlight camera is the pro 3 floodlight. I am thinking you must mean the essential spotlight (VMC2030).
Does power-cycling the base station bring them back on line?
No, they are actually online. It’s only on the app when I go to the device page and try and live stream that they switch to it saying offline
And what do you do after that happens???
Once they switch to appears to be offline, they stay that was on the device page. Even though they say that, they continue to work. If I hard close the app and open it again, I can see the cameras on my device page again for a few seconds then they all switch to appear to be offline.
What is the LED status on the base station when the cameras shift to "offline"?
All green
All green
Ok. When they go offline, have you tried shifting to your other device (iPhone to iPad for instance), and see if the other device also shows the offline status?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
