Annual subscription
I got the secure annual subscription yesterday in hopes I would be able to record at all times. I was wrong I need to switch my plan to CVR but I want to be sure I’ll get my money back for the months I won’t be using the annual subscription. I tried cancelling it yesterday and it said “sorry to see you go, you’ll be able to use subscription til Feb 14th 2023.”
They don't refund when you cancel - one big disadvantage of the new annual plan.
CVR requires more than a subscription. You need to connect the camera with a base/smarthub, and you need to provide AC power to the camera (solar won't do it).
Although expensive, I do suggest going with both for a bit. You can't download footage from the CVR stream, and it can be time-consuming to look for a specific event. So having motion-triggered recordings as well can be useful,
we’ll that’s kinda crap of them
$120 for literally nothing
thank you for replying though!
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
