Always armed door
Is there a way to have a door that's always armed even when the the system is on standby. Tbh id be fine if even just the siren went off once the door is open.
Id need a way to turn it off and on easy if I ever need to go through the door.
Yes, you just add a rule for the front door sensor to the standby mode.
You can also add a widget to the dashboard for the sensor. If you go into the settings from there, you'll find there is a toggle to enable detection that you can turn off. This does take a few steps though.
Also, since you have three modes, you can set up Arm Home to keep the sensor operational, and switch to Standby when you want to disable it.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
