APP is not working?
  • 1 Reply
  • 1024 Views
eastmanauto1
my APP is not working? I have removed it and downloaded it several times.  What should I do? The camara appears to be working but I cannot see any notifications.
Are you the owner of the cameras? Have you checked the active mode to be sure that the correct one is in use? Which cameras are you using and are they connected to your WiFi or to a base or hub?
