My android device was a trusted device. When I was login from web browser via my device for 2-step verification, no push notifications was shown on my device and the web page show "Login Denied." after a few second. I have re-installed the app, remove and trust again but the push notification could not be received. How could I fix it? Thanks
Have you tried contacting arlo support via the app settings support page?
Same problem here, did you get it resolved?
Same here. Another thing that company can't get right.
The problem still could not be fixed.
I chose email instead of phone for verification and I received an email with the code. This fixed it for me, good luck!!!
Yes, that works. The point is that the app is supposed to notify also, which doesn't work anymore.
oh sorry, mine does now that I got back into my account. I hope you can get that fixed.
Same issued. Can use others method via email or text message but push notification did not work only.
No, I got in through email verification. It wasn't an option on my phone but, it was on my laptop. Strange but I'm in!
Thanks for the clarification, glad you made it into your account.
The original issue is that the 2FA push notification is not working to some customers mobile devices which is still broken I believe.
The way to get around it is to have email access on a pc and use the arlo web portal choose another method option to trust the 2FA request.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
