night vision
  • 1 Reply
  • 2851 Views
CRAZYHIPPO
I HAVE AN ARLO Q AND EVERY MORNING THE IR WILL NOT TURN OFF EVEN WHEN THE SUN IS FULLY BRIGHT AND THE ROOM IS BRIGHT. THE PICTURE IS ALWAYS BLUE UNTILL I RESET THE CAMERA THEN IT GOES INTO REGULAR VIEW..AM I DOING SOMETHING WRONG OR IS THIS NORMAL?? HAS ANYONE ELSE HAD THIS PROBLEM AND WHAT SHOULD I DO.
Do a reset of the camera...holding the reset button till the front led flashes
u will have to resync the Q again.
if it continues to happen then it may be defective
