is Arlo Q compatible with AT&T Netgear 7550 ADSL2+ router
  • 1 Reply
  • 3065 Views
LEH
Is Arlo Q compatible with AT&T Netgear 7550 ADSL2+ router.
3 Arlo Q cameras setup 4 feet from Netgear 7550 ADSL2+ router will drop out and solid purple light wil come on after a few minutes.
Have tried cycling power, using reset button, moving cameras around and profanity (over and over). Nothing has worked so far.
I purchased 3 Arlo Q cameras and none will stay connected to internet
Is there any help or suggestions for my problem?
What is the data thru put on the DSL line?? Minimum  thru put is recommended at 1mb for the regular Arlo cams and Q's run higher.
The Q cams at best video ( 1080 ) can each peak at 1.5mb per
You could try an lower the rez to 480 which is closer to 300kb or so
