Can not get my Arlo Q cameras to connect
I am not able to get my arlo Q cameras to connect, I am a degreed BS CS and all of the setup is straight forward,
This is a new system, all for wireless cameras sync with the station and show up on my account, I follow the instructions
for the arlo Q cameras, enter the wifi name and password, hit the sync button, display the QR, camera chimes and
a few minutes later it says it fails. Tried it with the other camera same result. Depressed the factory reset button as
sugggested, followed the procedures, no joy. Do I have a set of bad cameras. I bought it at Best Buy and wondering
if I should take it back No phone support and the (408) number is always busy, I have 15 days to return but I would rather
keep it if I can resolve this issue/problem.
What is your data thru-put speed ?
Also in prev sw , the Q cam didn't recognize non-standard characters in the password ( which is also case sensitive )...if you have the newer sw in the cam I believe this was corrected.
fuzzylugnuts,
For more information on the issue with non-standard characters and instructions on how to setup a guest network to allow firmware to update, take a look at this article: Can special characters in a network name cause problems for Arlo Q?
Please let us know if this helps resolve the issue.
Arlo Q
