dropped sound/freezing on motion
  • 1 Reply
  • 2713 Views
Jjames124
When the system is armed and it picks up motion it will either drop the sound will start pixelating or freeze . My Internet speed is fast I'm not sure what the problem is .
This may be due to interference or weak signal to your home wifi....
Do you know the signal strength and what band your operating on... Mine works better on the 5 ghz band if you have that option
I would reset the Q and move it closer to test it and see if it is location issues
