  • 1 Reply
  • 2004 Views
YesG
I need to add 2 Arlo Q cameras to my system. I have a house in florida and I live in Calif. I want to add two cameras to the Florida system while I am in Calif and mail the cameras to florida and have them work on that system? Is this possible?
thanks
Yes they will work on your system.as long as the total cameras are under your service level .
Problem tho is that it needs to be set up with the local wifi SSID/pw as they do not hook into the base like the regular arlo cameras but hook directly into the home wifi.
