  • 1 Reply
  • 10325 Views
cazdazoz
Can anyone help me find out if there is a format for the URL for the mjpeg stream that I can use to access the camera feed from another security app (haiku).  Thanks
You can't... other than d/l the file and then import to the other prgm.
The transfer stream uses a key when the base sends the request to view or record... there is no access into the base.
