Think my camera died
  • 2 Replies
  • 3878 Views
Rrynning
Have 5 cameras. One went off line have tried to reinstall it several times even tried to do factory reset but the light never comes back on! And I can't get it to work. Does this possible mean the camera has given up the ghost?? Has anybody had any luck with warranty on a fairly new camera with netgear and a possible replacement?
steve_t
Master Master
No LED lights at all? Probably need it replaced. If you can take it back to the retailer, that's easier, otherwise you can Contact Support at the bottom of the page and do a live chat with an agent and get an RMA number
TrulsZK
Also you want to make sure it is the camera and not the power adapter / cable. Is it possible to test swap camera / power adapter / cable.
Then contact the retailer for a replacement.
