Temperature range
  • 7958 Views
QueryString
What is the temperature range for Arlo Q?
Placed in an outdoor storage it works fine down to 35 deg. F (2 deg. C), for now at least. But in the winter it could be as cold as -4 deg. F (-20 deg. C). Do I have to worry?
hokeysmoke
Virtuoso
Virtuoso
The temperature spec for the Arlo Q is -10C to 50C.  Customer Support has confirmed this, and it is also located in the Netgear 2016 retail guide.
https://www.netgear.com/landing/mobile/index.html#p=106
Unknown.  It's designed and marketed as an indoor camera which implies heated space.  It may be fine but if outdoors, you'd need to provide weather protection.
Couldn't find temp specs .
But, I don't think the lower temp will be a problem as the Q cam stays warm from being powered all the time.
Tho there is a thread on 1 Q cam shutting down with the heat at over 100d F.
hokeysmoke
Virtuoso
Virtuoso
