  • 2289 Views
YYZ-Arlo
Hello
I cannot find a photo of the power adapter for the Arlo Q, could someone please post one?  Does it use an A/C Adapter, or is it just a standard 2 or 3 prong AC outlet?
Thanks!
YYZ-Arlo
Disregard, found an image.  Thanks
YYZ-Arlo
Elvisj
I have lost the Arlo Q power adapter somewhere in the house. What does it say the requirements are on the plug? Is there a model number?
Assuming you mean the wall wart power supply, you should be able to use any quality power supply that supplies 2A. If not using the original cable, make sure it's a qua!with one, too, since the cheap ones use smaller wires while will affect the ability of the camera to draw sufficient power.
