Only receive notifications for outside camera instead of inside
  • 1 Reply
  • 1090 Views
JPreview
I just need someone to realize this and fix the software issue in an update.
2 arlo q cameras purchased. Both in the home.
1. Pointed at outdoor front entrance.
1. Pointed at indoor entrance.
Both are recording movement. Both work well. Both notify me.
That is the issue. I’d like to have only the outdoor camera notify my phone. The indoor camera I’d like to turn off notifications. Between, kids, cats, dog, anyone being home I’m constantly getting notifications of movement.
I’d absolutely want to know if someone is at my door, but I don’t always need to see the movement inside the house.
In the notifications portion of the settings I’d like the “option” to be allowed to only be notified per camera. Not a “all” cameras or “no cameras” type of notification. As it doesn’t specify. Just the option to turn off or on notifications.
Turning off the indoor camera negates it’s purpose so I do not want to do that, but to have the option to be only notified when my outdoor camera is set off would be great asset.
Since you are running 2 Q cameras, each has their own MODE to arm....
Why not edit the Indoor camera's mode and toggle off the email/alert settings... easy fix;
MODE/ pick indoor Q cam/ edit ARMED / toggle off the email or alerts or both as needed
If you want to use the alerts when away from the home, create a custom Mode with the Alerts on and use that when gone from home to arm
