Night vision turns itself on each night
  • 3377 Views
1902
I have night vision turned off but each night at dusk the night vision activates on the camera even though it is set to off still.
Given that I have the camera inside but looking out a window, all i see in the vision is then the infra red lights glowing back at me. The
only way to revert back is to reset the camera.
Any ideas on how I can make sure the night vsion stays off?
Thanks!
Try and toggle the illuminators off and on a few times ( save each time ) and see if it stays...
If it continues, put in a trouble ticket
Whzat firmware is the Q running?  It should be 1.8.0_5551.  Older versions seemed to cause this.  I haven't had an issue in some time.
1902
Thanks for the feedback.
Running 1.8.0_5551
I may do a factory reset on the weekend and see if that changes anything.
