My old Q worked perfectly moved it to a new house changed the Wi-Fi settings.
They are low-key worked perfectly but when we moved it to new building had to change the Wi-Fi. Connected to new Wi-Fi perfectly but when I unplugged it to permanently mounted could not get it to require the camera. Did everything I was supposed to over and over finally did a factory reset and camera will scan QR code chime will sound but then will never acquire the phone I have done this over and over. None of the fixes that have been listed seem to work I assume the camera is OK because it did originally work. What next
You can attempted to set up the Q on a computer... my.arlo.com
If it works , then there should be no issue to power down and re-plug in where needed ( and it should re hook to the wifi )
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlo Q
