My Arli Q cam play only in short sequences
  • 1 Reply
  • 2682 Views
MHE72
My Arli Q cam play only in short sequences usually 15-16 seconds when motion is indicated or sound. Can not you set it to do more film clips so you do not get lot of short films?
You can increase the lenght of the recording....
Go to MODE, pick q cam, pick the mode your using, click on the edit " > "
pick camera ( if more than one ), and hit edit
drop down to "record video" and edit that
the next page has a slider bar for time up to 30 sec or a button to pick for if motion continues up to 300 sec ( your choice)
hit the back button for previous page and at bottom, SAVE
