Arlo Q picture upside down
My camera shows the image upside down, even though I have inverted image under settings. The image is right side up when you look in the settings but not during live view
Arlo Q
Try toggling the setting, saving each time. If no go, reset the camera using the reset button until the LEDs flash amber and the camera clicks. Resync.
Arlo Q
