  • 4547 Views
Joemac8
I just connected my first Arlo Q camera. It works fine. I now want to move it to a different room in my house, on the same router.  Can I just unplug it and then plug it in in the other room or do I have to do something else?
Just unplug and move...if the wifi from your home is in range it will resync automatically
If led is flashing purple, the cam may be at about max range
Mondowgirl
I did this and had to start all over
Mondowgirl,
Moving Arlo Q from room to room should not create an issue unless you are connecting to a different router.
What prompted you to start over?
