  • 4 Replies
  • 3776 Views
  • 2 Likes
Doxiemom1
We just purchased and installed Arlo with 4 cameras. We are planning to add a 5th camera and just found that there is an Arlo Q with audio. Can we purchase and install an Arlo Q as the 5th camera without changing out the base station?
Yes.  The Q camera has nothing to do with the base station since it uses WiFi directly to your router.
As a ps;  the 5 camera max amount counts all cameras be it Arlo or Q... unless you buy the CVR service, then the Q won't count in the total
Both cameras will appear in the program together but they do have to be ARMED separately ... You arm the Arlos and then must arm the Q camera
Doxiemom1
Awesome! Thanks for the info!
Doxiemom1
Great to know!  Wish I'd known about the Q before I bought the system!
