Mic can't connect on T-mobile LTE
I would put in a trouble report to Netgear Support; https://www.arlo.com/en-us/support/contact.aspx
So I've been having this issue for awhile and it's been super frustrating because one of the main reasons I got Arlo was two-way communication with my dog if he does something he's not supposed to, like get on the counter... I followed all of the suggested remedies (uninstall, reinstall, power cycle phone, remove cameras, reinstall cameras, rest base station, factory reset phone, reinstall,...) Nothing worked. Turns out there is a solution, better, a work around. If you have a VPN that blocks IPv6 (I use Private Internet Access) the microphone will work over cellular. I believe (no expert here...) T-Mobile prefers IPv6 and it's not supported by the Arlo Pros (at least not for the two way audio), and P.I.A disables IPv6 to prevent "IPv6 leaks".
TL;DR
If you must have two-way communication, use Private Internet Access
Hope this helps.
I am experiencing this same issue, and opened a support ticket over a month and a half ago, with no result or resolution in sight. Has anyone found a resolution for this issue that does not require me to pay for a separate subscription or service? Thank you in advance.
Arlo Q
