Guten Tag
Beide meiner Kameras sind auf dieselbe Zeitzone UTC + 1 eingestellt. Die Aufzeichnungen der einen zeigen immer eine völlig falsche Zeit an.
Was kann ich machen?
Danke für die Hilfe, Rillmann
Are they showing summer time now (UTC +2)?
Also, is this just affecting the recording times you see in the app? Or are the notifications also wrong?
If you make a manual recording while livestreaming, are you seeing the correct time?
Both show UTC + 1.
Despite of that, one camera shows the correct recording time, the other one is 13 hours behind.
When I do manual recording, both show the correct time.
Have you tried restarting the camera?
Not yet.
I will, thanks!
Arlo Q
