Issue Creating Zone with Arlo (Q)
  • 6 Replies
  • 4731 Views
Sammy313
I just got and installed a Q. I cannot set up monitoring zones. I see the picture from the camera fine when I am just watching the video. When I try to create a Zone to set up monitoring, it doesn't show me my video feed. I just see a gray background and a white resizable box. No video. I tried on my Laptop as well as my iPhone. Same result on both. Help please.
6 REPLIES 6
Try resetting the Q using the reset button until the camera clicks and the LED flashes amber.
Sammy313
Since I can see the video fine in the regular monitoring software screen, why would it be a camera problem? Sounds like a problem with the Create Zone software.
I could easily agree with you but without a known configuration of the camera we'd both be guessing.
Sammy313
OK. I did a reset. Exactly the same problem, plus I am back to a previous problem where the option to invert the picture is grayed out. So now I have two problems.
Contact support using the Support link above. Maybe it's a bad camera.
Sammy313,
If seeing the same results from both your mobile app and browser, I advise contacting the Arlo Support Team for further investigation as suggested above.
You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
