How flexible is the subscription plans?
  • 4265 Views
  • 2 Likes
evelynyang
I only need more than 7 days or cloud recordings several times a year. Will I be able to change from basic to premier and back to basic?
You can buy a higher plan on a PER month basis, so yes
BLV
There are other subscription plans available, however for those limited areas only.
Actually , this should have been shown very obviously on web and in account.
As it took me a big while to realize I can not buy other plans just because I live outside those service areas.
After login, in buy subscription section there should be big sign such as YOU LIVE OUTSIDE SERVICE AREA, YOU CAN ONLY USE BASIC PLAN, etc.
By the way, is there any way that netgear put away this limitation, or provide some other options so that all users are able to save online just like other plan no matter where they live ? Or this limitation will be forever ?
Thanks.
One way to possibly do this, if at all possible, is to remove the system from your account and take it to a country that has the plans available to set it back up using a credit card from that country.  A royal PITA but may be the only way to get a timely resolution.  If purchasing new in one country to take to another, doing this initially helps avoid the problem.
The subscriptions don't seem to be getting updated often (if at all) so this is probably your only option.
