  • 4 Replies
  • 32612 Views
  • 5 In Conversation
hokeysmoke
Virtuoso
Virtuoso
I have attempted a few times to reset my Q and Q Plus using the "reset" hole on the camera, but it does not seem to do anything that I can detect.  There is no information in the user guide about this function.  What is it supposed to do, and how are you supposed to do it?  Do you push with a paperclip and hold, or do you push and then apply power?
hokeysmoke,
As stated above, the reset button needs to be held in excess of 10 seconds. When the reset has been successful you will hear a "click" and the LED will then begin flashing amber after a short pause. A reset can also be achieved by logging in to your Arlo account and removing the device listed under Settings.
JamesC​​​​​​​
gilbo2
Luminary
Luminary
I believe you need to press it for 30(?) seconds. After that you will need to set up the wifi details again.
Yeah, it's a long press. I forget what happens when the reset actually occurs (likely a flashing LED and at least one click) but it should be obvious.
Push in the reset with a paperclip for aprox 10 seconds till the FRONT LED starts to flash amber
hokeysmoke,
JamesC​​​​​​​
