  • 2 Replies
  • 1480 Views
DZawora
the live stream says it only supports max 5 streams. How do I turn off streams?
brh
@DZawora
I believe what they are saying about 5 live streams is that if you have more than 5 cameras turned on in the app, and yu want to go to Live View fo all of your cameras, you can only use Live View for 5 of the number of cameras. To turn off Live View, simply turn off one of the cameras, or only select Live View for the 5 cameras you wish to view..
Or if you have more than 5 Arlo Q cameras, you can only view 5 of them live.
Brian
Don't forget that it's 5 streams max PER BASE. Use a second base and spread things out. But that isn't an issue with Qs since theyre each separate. Then you have to be aware of your max upload speed from your ISP.
