How do I set up Arlo Q on Androidblue light blinking
  • 1 Reply
  • 2902 Views
lolem
Last night set up the Q, it was fine. Today I can't connect to internet with camera. I just keep getting the blinking blue lite. I'm doing this on a iPad. I've reset and not getting any different results.
Camera will be in MN,  can my brother in Texas check out feed while and I'm watching in WA?
thank you,
BS
Reset the Q camera ( hold reset for about ten secs till the leds flashes amber...re-sync as if new.
( the ios app is acting funny ,from the last release, so do on a PC )
As to your brother viewing, Yes... add him as a guest (SETTINGS>GRANT ACCESS) and then you both can view at same time.
