Help With Setting Up a POE Camera System
  • 1 Reply
  • 1446 Views
Oliver123
I would like to replace 2 outdoor hikvision POE cameras (one dome and one bullet)  with 2 Arlo cameras- and then add 2 more Arlo POE cameras.
I currently route all my POE through a Linksys 16 port switch and then record all my security triggers on a dedicated server.  I use Blue Iris on the server and for some IOS mobile access.
Which camera should I use for this external POE setup?
Is this a straight plug and play?  Do I simply plug the CAT 6 into the back of the Arlo camera?
Do I need any other hardware or software to make this work?
Can I link the doorbell into the same configuration?  does its also support POE ?
Well, it may not play like you want... the Arlo cameras are cloud based. Even the Q plus which supports POE does not record to a local server (only has a mem card for backup)
