Geofencing problem. Reset camera or delete app?
I have two Arlo Q cameras & I'm haveing geofencing problems with one of them. One workes fine & is disarmed when I'm at home but the other when I try to use geofencing it arms itself although it is set to the exact location that the other is & I'm sat at home
Should I reset the camera & if so how do I do it? Do I just delete it off the app & add it again or something else
Phil
I'd remove it from the app and bring it back.
If you want to reset it, Hold the reset for about 10 secs till the led flashes amber and then resync may be needed
Arlo Q
