Does Sensitivity of Arlo Q Change by Time and What Can I Do?
  • 1 Reply
  • 3220 Views
Maram
I am very happy to have purshaced this camera that keeps me unworried while watching my baby at home from work. Yet, lately, I am not receiving as much notificationas as I used to. Sometimes, half an hour passes by without any notification, which is almost impossible. Usually, I get notification when the TV is on. Now, it is on almost all the time but there are no notifications. I can hear it playing when I go directly to devices. Motion, too, is not as sensitive as it used to be. I get one notification to many movements.
Could you please help me with the above. I remember setting the cam to maximum sensitivity in both audio and motion.
Thank you in advance,
from Maram and baby Sama
I don't have an explanation without being able to see if there were any changes.  It might be worth resetting the camera using the reset button until the LED flashes amber and then resync it.  See if that makes a difference.  Be sure to check your sensitivity levels again since this will reset them.
