Do I need to upgrade to Arlo Q Plus?
  • 1 Reply
  • 1117 Views
Mitchie23
Hi There, I've been using Arlo Q for 2 years now and so far so good, no complaints. The video is very clear at 1080p though not good at night. I have seen some reviews about Arlo Q Plus (thewiredshopper.com/arlo-q-vs-arlo-q-plus-which-one-do-you-buy) and thinking if I need to upgrade. The only difference is the physical storage and the POE? How important is that? 🙄
If the current one is working, and you don't need physical storage or POE then why?
They are the same except for those two features
If you already have cloud coverage on the Q camera, it sound like not needed.
