Dreaded Blue/Amber/Purple light blinking rotation?
  • 6 Replies
  • 3242 Views
Flicker6
Anybody able to recover from this condition or is the camera toast? Removed it, tried paperclip reset, it won't respond.  Only 1yr 3 months old.  Boooooooo
6 REPLIES 6
Did you hold in the RESET for about 10 sec till the led flashed ??
Flicker6
Yes, tried for 10, 20, 30 seconds and longer.  No luck.  Starts out solid amber, blinks once then after a few minutes of solid amber it starts flashing all three colors in succession
ShayneS
Hi @Flicker6
When holding down the reset button with a paper clip for 10 seconds, do you hear a click from the camera? Also, A reset can also be achieved by logging in to your Arlo account and removing the device listed under Settings.
Flicker6
The camera never clicks and I already removed the device under settings.
Sequence of events:
Plug it in - solid amber
Hold reset - after 15 seconds - amber blinks once
Wait 1minute and blue/amber/purple blinking rotation begins
Hold reset - after 15 seconds - blinking rotation stops, 1 purple blink followed by solid amber
Repeat
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Flicker6
Shane
I haven't had much luck with Arlo Tech Support, a lot of wasted time on the phone going around in circles.  What advise could tech support possibly offer on a device out of warranty?
