Det går inte att logga på min Q
  • 5 Replies
  • 3959 Views
Glenn00
Jag kan inte logga på min Q. Jag har skrivit in rätt nätverk och loggin.
mvh
5 REPLIES 5
One of the common problems if if your wifi ID uses spaces or special characters.
Glenn00
IT dosent. But should I connect to my net gear or my normal network? If net gear, how do I find the password?
No... the Arlo Q ONLY CONNECTS to your home wifi/router..
( the Arlo base sets up a wifi system for the Arlo cameras only and is not a 'normal' router )
There is no access to the Arlo base.
Glenn00
Ok.. Way dosent the Q Connect?
Don't know, but since you haven't been able to connect and your Home wifi SSID and Password are good ( have no spaces, special charactors ).
I would try a reset of the Q camera.
Hold in the reset on the camera till the front LED starts to flash amber ( aout 5-10second hold ).
Then try and sync to your home wifi system as per the directions again.
