I already have 2 Arlo battery cameras installed and have now purchased an Arlo Q. I cannot get it to connect to the Wifi.
Attempt to do a rest on the Q camera ( hold reset for about ten secs till the led flashes amber )
Try and sync again following directions with your SSID and router Password.
Are you using the phone app to set it up, if so. Try using your computer/laptop.
Arlo Q
