Camera is disconnected each night
We have a house alarm which works from the wifi system that the camera operates from. Each time the alarm is turned on it seems the camera has to be re-entered into the system. Is this normal? What is the best way to overcome ths problem? Help!
What alarm have you got? What router have you got? What internet connection have you got? What do you mean you have to re-enter the camera into the system? Is it just one camera that needs to be re-sync'd?
Sounds like you could be in New Zealand?
I would try changing to channel that your router works on (2.4GHz band) to 1, 6, or 11 and see if that makes a difference
I wonder if your alarm is interfering with the WiFi connection to that camera. You can swap cameras to see if the issue is with the camera or with the location. If it's the location, temporarily put your camera someplace else near the base to see if it still goes offline when the alarm system activates.
Arlo Q
