Both iOS and Android App cannot detect and setup my Arlo Q camera
  • 4 Replies
  • 2673 Views
eakcomp
I try to install my new Arlo Q via the mobile app on both iOS and Android. But the apps cannot facilitate initial setup and get me stuck at the QR code scan step and cannot find the camera. Product serial # is 4SS17CS656DDC. Thanks.
Are the phones on your home WiFi? It won't work on cell service to set the camera up. It might also be worth trying a browser to see if the same thing happens. You're not using a VPN, are you?
Try a full reset of the Q ( hold in the reset for about 10 secs till led flashes )
Attempt to sync.
eakcomp
Here is my setting...
  • Connect all cameras over WIFI on 802.11AC router on fiber optic connection
  • Already connect 3x Arlo Pro2 via Base Station successfully
  • The installation points are within the range of my wifi network, tested on Arlo Pro2 and my mobile phone
  • Not on VPN
Here is what I've tried to make the initial connection and unsuccessful on my 2x Arlo Q
  • Over both 2.4GHz and 5GHz Wifi
  • On iOS (iPad Pro 10.5 2017) / Android (Samsung Galaxy Note 😎 / And My Arlo web
  • Factory reset (10-sec push using the clip) for 20+ times on each device
Now, both 2 cams become 2 expensive bricks right now. Is there any other thing I can try? Feel free to propose 🙂
Dunno if it would help but are you using the same SSID for both WiFi bands? If so, try using separate SSIDs.
