Arlo camra sometime record black screen.
  • 1 Reply
  • 2783 Views
jackyu
The Arlo camera at my front door window sometimes record black screen.  Problem is gone is about 30 minutes, and problem come back once in a while.
The Alro camera lives indoor, but I have installed a motion sensor light bulb outside the front door, about 2-3 feet away from the camera, but they are divided by a concrete wall.
 What do you think it's the cause here? Should I return the Arlo camera for a replacement?
haven't noted this issue before... but I would reset the Q and retest...
If it happens again, either return for another or go thu Netgear Support for possible hardware issue
