Arlo Web Interface? Flash Player?
  • 2 Replies
  • 3274 Views
TheKiller
What's up with using the web interface to view the cameras, set modes, etc?
It used to work. Now I just get prompted to install the latest flash player which I do - and it still keeps prompting me.
Is the web interface dead? Here's the URL I use:
https://arlo.netgear.com/#/login
TheKiller
Nevermind. I had to find the G.D solution myself. See below. What a lame web app if it is misleading every user. What's the problem here?
I'm ready to junk my Arlo cameras and get something else. I can't count the times we have armed the cameras and someone has come home early unexpected, not a peep from Arlo. IM USING THESE AS SECURITY CAMERAS! THEY HAVE TO WORK EVERY USE THEM. EVERY TIME.
If your internet goes down, arlo just gets stuck. Great!
The zones won't work any more. Look - the cameras haven't changed. Can we get the clowns that are running the software to fix it?
https://community.arlo.com/t5/Arlo/A-newer-version-of-Adobe-Flash-Player-is-required-Please-install/...
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
