Hi Rtran15,
If your Arlo Q is showing a solid amber only, it sounds like the camera may be stuck on boot up. Try to unplug and wait a minute to re-plug back in to power outlet to see if that helps.
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I did contact the support team on Friday 10/4, and was provided with a case number. Karen one of their Support Experts had me go through the typical new setup protocol, but the unit still remained frozen. I have since left 2 additional messages to their support team, and have yet to receive any additional response which is pretty disappointing.
Let me reach out to you via private message to gather more information from you regarding your contact with the support team.
Arlo Q
