Arlo Q will not sync
  • 4 Replies
  • 6060 Views
chuckw246
I have 4 camera wireless system and want add the Q But the manual says not to add it to the wireless! and it says see page 8 which there isn't a page 8? I cant get the Q to sinc up?? What do I do??
You can't add it to the base station but only to your own WiFi.  Make sure the router's SSID and passphrase have only alphanumeric characters (no spaces or punctuation or other special characters) and that you're making sure the spelling, including caps, is correct.  Any help?  If not, give us details.
loriskip
have done everything and checked it many times over and still will not sync to the wifi and not the Netgear
Streak2
Master Master
Make sure that you are entering the correct SSID and password.
Also as mentioned above
"Make sure the router's SSID and passphrase have only alphanumeric characters (no spaces or punctuation or other special characters) and that you're making sure the spelling, including caps, is correct."
If for whatever reason your current router uses an SSID and password that has these special characters then you need to change these first before trying to sync the Q.
Use of the guest network on many routers may be a fast way to get the Q going, followed by firmware updates that may allow you to use your existing SSID and passphrase.
