Arlo Q vs Arlo Pro 2 for indoor use
  • 10437 Views
pdizzle
I want to install 4 indoor cameras (wired) and 1 outdoor camera.  Suppose price is not a consideration, would it be better for the indoor cameras to use Arlo Q or Arlo Pro 2 system?  Thanks!
If indoors, I would def opt for the Q cam
The downside you may want to consider is the Q cam are indivual units ( tho they all appear in app ) and must be armed separately ( the Pro2 cam are armed all in one step )
pdizzle
Thanks for your reply Tom - Can you explain the benefits of the Q cam?  Since both are 1080p and both can be powered via Wire - do you tend to see better resolution or better night vision with the Q?
pdizzle,
It might be beneficial for you to take a look at the comparison sheets here so you can see the breakdown of the features for each camera: Arlo Products and Accessories
