Arlo Q solid amber light
  • 2936 Views
enkhsaikhan
I have previously succesfully installed two Arlo Qs, but this shows solid orange light as soon as I power it up. Sync button and reset button both does not seem to work... What do I do in this situation? Thank you.
When doing reset, did you hold the reset for ten secs ?? ( till the led flashes )
enkhsaikhan
Yes I have tried the reset button both 10 second and even one minute. Also I tried the sync button. Both seem to be unresponsive. Just yellow solid light when plugged in.
Swap power supplies to see if that makes a difference. If it's a hardware issue, swap at the store or open a case with support:
