Arlo Q settings reset after power cycling
  • 2 Replies
  • 3566 Views
EFTC
Hello all,
I have 3 Arlo Q cameras connected to AC mains with stock USB power adaptor and stock USB cable.  I turned the front LED off and Night vision LEDs off on one of the camera.  In addition, motion detection zones has been set up for this camera.
I find myself having to re-enter all the settings and reprogram everything everytime the power is lost or when I power cycle the camera (unplug the SUB power adaptor for 1 - 2 min and plug it back in.  The camera connects to the WiFi network just fine which is a good thing.
Is there any way to prevent this from happening?
Running the Q also, never had to reset anything on it after power outage, pulling plug to move ,etc.
Next time it goes out, try a RESET of the Q ( hold reset in for temn sec till the front led flashes )
You will have to re-sync this time but in future all your modes, settings should stay
EFTC
Thanks for your help and advice.  I followed your instructions and it works.
